Glassing wing center
John,
I'd recommend the epoxy resin, especially if you can find the finishing resin as it is very thin. If not, you can thin out regular epoxy by mixing in denatured alcohol. Suggest you use a 30 min, or longer epoxy to allow plenty of working time.
