RCU Forums - View Single Post - 4* 60 completed!! Finally!!
Old 07-18-2008 | 08:17 PM
STRAUBMAN
Default RE: 4* 60 completed!! Finally!!
Thanks for all the complements. I was wondering about the leading edge. Two guys at the field said no problem. Well let me tell you. Dropping in over the trees on final was interesting to say the least. I definatly need to put some color on the leading edge. No pics of the bottom right now but I have two 4" white stripes on each wing. As for leading edge, I'm not sure what will look good and be functional. At this point I need something I can see or I may not have a pretty plane for long. Probably white. Any thoughts?
Frenchie. As for flying. I think it flys very good. Lots of power which I'm not used too. Not too fast though. Landings are a breeze. Actually need to give it a bit of power at the end. I need to increase the aileron throws a bit. A little slow on the rolls. The engine started making noises on the last flight. Sounds like an exhaust leak but it's not. I believe I have to adjust the valves already. About 6-8 tanks throught it.
