Su-Do-Khoi harrier
Krayzc
The aft CG limit on the plans is 6"behind the leading edge of the wing. My CG is 6 1/2" in back of the leading edge. I'm using the battery to shift the weight back and now I'm to the point where I'd have to add some wire to the battery to put it back any farther.
I believe I'm going to add a phenolic tube to the rear of the airplane so I can stuff it with lead to play with the CG. As of right now it is almost where I want it.
It does a neat inverted hovering flat spin and I'd like to get it to climb in this attitude.
Hover is no problem. Backing down in hover needs some work.
Knife edge loop is no problem. It flys very slow and so far I'm having a good time with it. I belive after a few more gallons of fuel it will do about anything I want it to and maybe somethings I never knew I could do.
