RCU Forums - View Single Post - Pressure fitting on tuned pipe and leakage/performance change?
Old 05-15-2003 | 03:03 PM
Unstable
Default Pressure fitting on tuned pipe and leakage/performance change?
if you lose pressure going to the fuel tank the engine will go lean.
I dont think that it being loose would make any noticable diffrence.
check the rest of the engine (carb, head, exhast manifold etc) to make sure everything is tight, if one screw came loose its possible more have too.
