RCU Forums - View Single Post - HOB Decathlon build
Old 07-19-2008 | 07:54 PM
kargo
Default RE: HOB Decathlon build
Somewhere in there I started to work on making some templates for the starburst pattern common to decathlons and shown on the kit plans. I used a glass plate over the plans, and clear plastic material for the templates, straightedge, and a sharp #11 exacto blade. It was a bit tedious, but not that bad in the end. I intend to use a trim sheet to make the starburst pattern. My thoughts are that white covering won't be as white over the red covering on the rest of the airplane.
ID:	993828   Click image for larger version
ID:	993829   Click image for larger version
ID:	993830   Click image for larger version
