RCU Forums - View Single Post - question about programable mixes.
Old 05-15-2003 | 08:08 PM
lownslo's Avatar
lownslo
Default question about programable mixes.
Hello Krysta, You answered...
If you are asking, can you set the second Pmix to work off another switch other than what the first Pmix works off of, no.
Both Pmixes will work off the same switch and there is no switch selection screen on the 6X as there is in the 8U, 9C and 9Z.
**** You will set your one Pmix up on your Pmix switch, but if you make the other mix active, it will also activate with the same switch.
I apoligize in advance for possibly being dense... but I still don't understand. 1. I do understand you can't assign task to another switch. 2. I "thought (?)" that maybe,both mixes worked off the same switch. 3. This is the part that I still don't understand.(See **** above in your quote. Evidently.... there is really only one choice..... either 1 OR 2, with that one switch. NEW Question... If I should program mix 2, how do I assign it when mix 1 is already on that switch? Can you toggle back and forth between the 2 mixes? Unless I missed something, the directions are not very clear in that area.
Thanks again.....lownslo....
Bob
