RE: pusher prop
Just putting a prop on backwards will still provide thrust in the same directon, in fact that was a trick in the days of RC with rudder only was to install the prop backwards when the airplanes climb rate was excessive.
If you reverse the polarity reversing the motor then the prop will need to be installed backwards.
John
