RCU Forums - View Single Post - need advice on the center of gravity
Old 07-19-2008 | 09:20 PM
da Rock
Default RE: need advice on the center of gravity
BTW, those two sites appear to use identical software. It's surprising that they would give different results, since it's obvious they use identical user interface code.
geistware's results have proven to be absolutely reliable over the last 3-4 years of use. If you input correct measurements, you'll get trustworthy CG recommendations.
