RE: Eagle 50 T-shaped Hub
Andy,
No. The hub is brand new. I assembled it correctly. I got it flying today. I had to drill the holes at the top of the hub larger for the dowels to fit. I got them in tight then tapped them home. As far as the slop in the block is concerned, I used some ca glue and glued the upper to the lower. We shall see how long that holds up. Alot of work for a part that should be ready to rock. I think i'll get another one on my next parts order.
I was just wondering if anyone else has had this experience?
