RE: Classic Pattern Plane Image-base
Changes to the Classic Pattern Plane Information Site! Good changes!
[link=http://www.trentonrcflyers.com/pattern/pattern1.htm]Classic Pattern Image-base:[/link]
I have restructured the image-base to make it easier for me to add planes without having to periodically re-order the images in alphabetical order. I now have a separate page for each letter of the alphabet. Well, nearly. It is also easier and more intuitive for a visitor to find a plane they are interested in. For example, the MK Arrow is listed on the "A" page and the "M" page. I will make an effort to indicate when an image was added to the image-base so repeat visitors will have an idea of what they have and haven't seen.
[link=http://www.trentonrcflyers.com/pattern/classicpatternlist.htm]Classic Pattern Plane List:[/link]
Here is a work-in-progress to compile a complete list of Classic Pattern Planes, their specifications, designer, kitter, etc. Please submit any information you might have with respect to any plane in this list. If you know of a plane that should be in this list, please let me know using the contact information at the bottom of this page. The criteria for a plane to make this list is primarily date. Since this list is not limited in scope as, for example, the Senior Pattern Planes association's list, establishing a cut-off date for a qualifying plane is a matter for discussion. There are planes from the mid-90's in the list.
Keep the contributions coming!
CAsniffer
