RCU Forums - View Single Post - Installing fuel tank suggestions (another question added)
Old 07-20-2008 | 11:24 AM
Rufcut
Default RE: Installing fuel tank suggestions
I use sill seal foam from the local hardware store to wrap the tank. Then CA a stick of 1/4" x 1/4" balsa to hold the tank in place. If or when you want to remove the tank you can just break the balsa stick and remove the tank.
