Tip Stalls....
Check the wing tips, make sure that you have a slight-but-equal amount of washout in each wing. That may/will likely mimimize tip-stalling.
Otherwise, it's a scale warbird and you may need to come in a bit hot as SOP.
Have you considered cutting the inside portion of the ailerons and converting them into flaps?
