If I could offer up some advice? Get your needles right for a good transition , Your going to want to lean the low out 1/8th at a time till it starts stumbling then richen it back 1/8th-1/4 turn and richen the high back down 200-400rpm(you know the drill Im sure
) The 14x4w is the prop you want,(for3D) I havnt tried a vess yet but I did try the other woodies and they really disapointed.
Trust me I ABSOLUTELY LOVE THIS PLANE! I want you to love it just as much as I do
Flew mine all weekend .
You may find the CG needs to go back farther then the prescribed amount also.I have moved my battery back two inches now and it gets better and better as the tank empties.
It was set right in the middle of the tube to begin with.
Im still dialing mine in and its getting better and better!
Mike,
