RCU Forums - View Single Post - Concept airfoil design- des it work?
Old 07-21-2008 | 12:26 PM
Lnewqban's Avatar
Lnewqban
Default RE: Concept airfoil design- des it work?
Yishht87:
Try this software:
http://www.grc.nasa.gov/WWW/K-12/FoilSim/index.html
Not exactly what you want, but very interesting to learn from, indeed.
It would be good for you to study about Airfoil Pressure Distributions at:
http://www.desktopaero.com/appliedae...pressures.html
Besides, find an interactive java diagram at:
http://www.desktopaero.com/appliedae...etryandcp.html
Diagram #2 is closer to reality, I believe, since the little bump of #1 cannot deflect air as shown.
Such a bump can induce some turbulent flow only, which could help the lift only if used on the upper surface (it is called turbulator).
Regards!!
