RCU Forums - View Single Post - Purple Brushless Electric Ultimate BiPe
Old 07-21-2008 | 12:57 PM
  #85
opjose's Avatar
opjose
Default RE: Purple Brushless Electric Ultimate BiPe
ORIGINAL: SHEPSTER
also to connect the airlons and elevator they gave me a few paper/tnin plastic pieces. do i ca these on the ultra cote (just glue to covering on ouside) or am i suppose to slit cut and stick them inside the airlon then cut wing side and slide it in that way.these instruction are very grave.
No.
The trailing edges of the wings, rudders and elevator have slits cut into them.
The thin plastic pieces get slid into the slits and the control surface attached.
Once everything is in it's final position THIN CA is applied.
It seems that you may be new to all of this.
As such please read this manual. Though it is for a completely different plane, the tips are applicable as are the directions for installing the hinges.
[link=http://manuals.hobbico.com/gpm/gpma1546-manual.pdf]Manual[/link]
If possible obtain help from a more experienced builder.
