RCU Forums - View Single Post - HOB Decathlon build
Old 07-21-2008 | 04:03 PM
NorfolkSouthern
Default RE: HOB Decathlon build
I really like the laser cut of this kit. Everything fits much better than a die-cut, and the pre-shaped spar helps greatly in aligning the ribs. The one wing side I've built so far turned out very good and strait, the leading edge fit perfectly. That's a lot more than I can say for my last winter's project, which required a lot more sanding and fabrication.
NorfolkSouthern
