RCU Forums - View Single Post - T-Rex 600E Pitch range adjustment problem
Old 07-21-2008 | 11:43 PM
Anything R/C
Default T-Rex 600E Pitch range adjustment problem
Hi all,
I just finished building my T-rex 600e GF kit. I am in the process of setting it up. I set it up very precisely as far as everything being 90 degrees, the swash being level, and how long the linkages are. I have a swash leveling tool. And I measured all linkages using a caliper.
Somehow, I ended up with +10/-8.5 degrees of pitch. How do I bring down the top end, and raise the bottome end, so that I have approximately +9/-9.
Right now, at center stick, both blades are exactly zero degrees.
I also noticed that, one blade is half a degree higher in the high and low end than the other blade. But both are at zero at center stick.
If I adjust it at the blade grip linkage like the tracking adjustment, wouldn't that throw off the zero degree @ center stick?
