DP Edge 540 HELP!!!
I understand your frustration. When I build, I mount the engine, cowl, and prop assy plus all of the control surfaces before cutting or mounting servos. You can then check the CG with servos taped in place. You may still get the CG to come in if you put the battery in the tail. I do a lot of planning and adjusting before committing to a servo location. Not to insult, just a tip for posterity.
