RCU Forums - View Single Post - Hitec Eclipse Question
Old 05-15-2003 | 07:35 PM
screamn1
Default Hitec Eclipse Question
First of all I'd like to say that I have had no problems what so ever with my new Eclipse Spectra system. I used to use the JR 347 so programming was nothing new.
My Question...
I've got an aircraft that is set up using the Acro settings. It was flown using a single aileron servo but after realizing that it was landing really hot, I added a second aileron servo so that I could use flaperons to slow the landing down a bit. After setting the FLPN to on and setting the FLPT to "0", I set the right and left airerons throws and endpoints to specs. I then went back and added 30 percent to the FLPT setting and noticed that while doing this, both ailerons went up as in the spoiler position. This is when the ch 6 (VR1 knob) is turned all the way to the left which I now see is the negative side. So correct me if I'm wrong but using this option allows not only flaperons but also spolierons...right. But I would just have to make sure that the knob is at its "0" position when taking off.
If I chose to only having flaperons, would using the "Landing mode" be my best option to just be able to flip a switch during landing and have the flaperons and elevator set to a specific setting kick in?
Thanks for your reply and comments.
Palmer
