RE: Jet Shot Down by Farmer
If this is the field I am thinking it is there have been numerous issues with this farmer. I am not a member of this club but have flown there a couple of times. All of the members will warn you. "if you go down over there consider it a total loss". One of the ends of the run way is about 100ft or so from the edge of his property. A left to right pattern has you taking off into his fields, but a right to left pattern would have you slow flying over his field to get back to the run way. Attached is a picture of the club. You can see the farmer field at the end of the runway.
