RE: New TF Sea Fury!!
Thought I'd throw my 2 cents worth in about nose weight on the fire wall of the TF Seafury. Here are a few photos of my retract install.
Everything is in the center wing section as close to the CG as I could get it. No connect/disconnect when assembling to fly! The pressure gauge is all that needs to be connected for flight. It's protected by a check valve. I plan on installing either a Thunder Tiger 120 or an os 91 2 stroke and do not want to mess with adding weight!
