RCU Forums - View Single Post - GS Storm RTR Engine break in * Need Help *
Old 05-20-2003 | 12:10 AM
RCCarAddict
Default GS Storm RTR Engine break in * Need Help *
ok...
1. take your air filter off and check the carb...if you can see a pretty wide gap when u are idleing it, adjust the throttle stop screw until you can barely see the gap. OR
2. adjust the throttle servo and brake linkage so that the throttle is COMPLETELY closed when the servo is at its "home" position....if your car won't stay running after that, slowly increase the throttle trim
good luck
