GS Storm RTR Engine break in * Need Help *
A little advice, before you even think about starting your engine always do a radio check. More than likely the trim settings on your transmitter are not set correctly, or the linkage on your throttle servo is not set up right. There should be like a 1 or 2mm gap in the barrel of the carb at idle so if there is more than that reset the idle screw or set the linkage from the throttle servo.
