RCU Forums - View Single Post - Flaperons
Thread: Flaperons
Old 07-23-2008 | 08:10 AM
Stick 40
Default RE: Flaperons
Hi,
I have the funtana X mini , and am using the JR X9303. I have flaperons on it, and they seems to work real well. I have a lot put in, I'll get it and check how much I have. I also put in auto land ( that adjusts the elevator for me, when the throtle is moved to a low level) . I don't think you will need much down elevator at the lower speed for landing, if thats what you are doing. I can floot mine in at slow speed in just a little wind, but I tested it at a high alt. before trying to land. I must have played with it a couple of flights before trying it for a landing.
Ok, I'm back hope that did not take too long for you!!!!
The first setting is a 1 inch drop and the second is 1.5 inch drop ( don't have a degree for it), and I have not used the second one (1.5 inch) . I have broght it in , in very little wind and just about landed on a spot landing. I have not seen any indication of a tip stall problem on mine, but I do watch for it and it can happen( remember when you play sometimes you pay).
let us know how you come out.....
