RCU Forums - View Single Post - PROBOAT APACHE 24
Old 07-23-2008 | 08:17 AM
hoverhog
Default RE: PROBOAT APACHE 24
Well this is what we have done so far to our Apache24
Relocated the antenna to clear the hatch
Installed floatation foam on the hatch
removed the decals from the top of the Hull as they started to peel off after the first coulpe of runs
I have found that the speed control is rated for 12v and 50amps so we have been running a 11.1v lipo 2100mah
This realy wakes this boat up and makes it run how you would expect a cat to run
Stability is compromised so i think im going to install turn fins or it will flip in the turns
