RCU Forums - View Single Post - Prop Spinning backwards
Old 07-23-2008 | 09:15 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Prop Spinning backwards
While the words "Engine" and "Motor" are somewhat interchangeable, "Engine is used to describe "fuel burners" while "Motors" usually mean "Electric"
When an engine starts backward, it is usually a sign of it having too much fuel in the mixture - often from having been over-primed.
Sometimes, when the engine is running backward, opening and closing the throttle can make it "Hiccup" and reverse direction. Usually, the engine just dies and needs to be restarted
