How to mark your depleted battery
I think a small bit of tape over the plug when you finish the charge. that way you have to remove the tape to use it making sure you dont forget it on there. or rubberband the wire back on the chaged packs so you take off the band to use it.
its easier to remeber to do something if its "in your way" like that.
all you have to do is remember to put it on after charging them.
