RCU Forums - View Single Post - engine trouble
Old 07-24-2008 | 02:47 PM
richrd
Default RE: engine trouble
running at night is not to safe because the 60hz of powered light effects the tach reading. So turning the lights off an using a flash light works butit's a little dawnting. The spring in the barrel should hold it tight I'd try to tune it first then look for air leaks. Search for the pinch test to set needles.
Rich
