RCU Forums - View Single Post - engine trouble
Old 07-24-2008 | 03:34 PM
Steve Steinbring
Default RE: engine trouble
Steve,
I don't really know what you mean by choke!
The carb barrel should close all the way when the throttle trim is moved down. Sounds kind of like a linkage trim problem to me, although there maybe a problem at the carb that will not allow the barrel to fully close. Once you have the carb barrel opening and closing fully you should be able to set a good idle. This will allow you to taxi out and land at idle or just above, then trim down to shut the engine off once the flight is over.
