RCU Forums - View Single Post - Keep quite. Neighbor complaint
Old 05-16-2003 | 11:46 AM
Celly013
Default Re: Keep quite. Neighbor complaint
Originally posted by calvinsj2003
Hi All,
My GS storm cause a bit of noise from the stock pipe. I wonder if you guys know how to low it down or any other quite pipe that i can replace the stock pipe. My neighbor just complaint that my GS storm cause such of noise from the engine. Pls! help.
I also owned a Tmaxx. The pipe noise is OK, no neighor complaint when i run it.
Just find a better place to run it... Once your under their skin, you know that even the whine from an electric will tick em off.
If that is not an option, Try:
1. Pointing the Stinger more downward, the ground might help absorb some of the sound. (Might be hard on a buggy)
2. I was once told that a small amount of tube on your exhaust will quiet it down, and keep fuel off your car. Don't know how true this is.
3. Depending on what engine your running, there should be 100's of pipes to choose from, but honestly, I have never heard a truely quiet big block buggy.
