RE: Gasoline Heli help
check your tail section as sometimes the set-screws come loose on the shaft and it will slip when under a load and be fine at times this condition will get worst if left unchecked also if your tail has a long control rod that are 2 pieces (like the raptor) where the 2 rods come together there is a connector check that as they come loose at times also
