RCU Forums - View Single Post - Concept airfoil design- des it work?
Old 07-25-2008 | 10:53 PM
Lnewqban's Avatar
Lnewqban
Default RE: Concept airfoil design- des it work?
ORIGINAL: Allfat
lnewqban,
The Reynolds number for the transition from laminar to turbulent that you posted (2100-4000) is valid for pipes and enclosed flow. This is not the situation we see in an airfoil and the transition occurs somewhere in the vicinity of a reynolds number of 500,000. This is of course assuming a perfectly smooth surface, which is not really valid because no such thing exists. So in reality, the transition will be before 500,000, but the point is it is a lot higher over a plate or an airfoil than flowing through a tube.
Correction has been done to value of Re number in Post #9 above.
You are correct, Allfat; critical Reynolds number for open fluid around an airfoil is 500,000 approximately.
Thank you!!
