RCU Forums - View Single Post - What battery tech are you using?
Old 07-26-2008 | 10:36 PM
jetpack's Avatar
jetpack
Default RE: What battery tech are you using?
I just started looking at what flight pack to use with my first 1/2A RC effort. I'm building a stick built 38" Citabria which is designed around the old "schoolyard scale" catagory and will have a throttled Cox .049TD. It has about a 10oz-12oz weight minus radio gear.
Since I would like to build it close to scale, I would like to add seven LED's for strobe, dash and nav lights.
I have four eFlight 9g servos, and planning on getting a Berg 4L reciever.
I like the idea of running a voltage regulator due to the LED setup.
I guess my question is this still in the bounds in which you guys are talking? If so, I'm hoping someone like Tower Hobbies carries it.
