RCU Forums - View Single Post - Servo Problem
Old 07-27-2008 | 12:28 PM
Redharris's Avatar
Redharris
Default RE: Servo Problem
Tilux.......
If the Battery is getting Hot, then you have a Short circuit somewhere....
I agree with Eddie. You probably have a Damaged receiver.....
Moisture, of Any kind, is BAD for electronics....
Water will not always kill electronics Right Away.
Sometimes, the component will last for awhile before it fails completely.
You are Lucky. If the Throttle channel had filed, you might have had a Run Away.....
