RCU Forums - View Single Post - The Super Decathlon
Old 07-28-2008 | 08:59 AM
oldernut
Default RE: The Super Decathlon
ORIGINAL: CGRetired
As Ken was trying to suggest, get back to basics and learn to fly on the wing. Be satisfied with the performance of the plane because that's what it does.
CGr
GaRCfield.
Many people have given you some pretty good advice. RCKen spent a lot of time typing an answer. You should heed his advice.
CGRetired Says a plane does what it does. He is absolutly right. You have to adopt because it can't. Or doesn't like to If you make it do things it doesn't like, it will turn and bite you. (or the ground)
I have three friends I fly with, both full size and models. Bob, my hangar partner, is always saying: "you have to make friends with the airplane". Give it what it wants and it will work for you instead of against you. Learn to give the plane what it wants and it will become your friend. So, you have to learn to fly each plane a little differently from the others.
Oldernut
