ORIGINAL: Shubova
Get a long thin wire; I use a wire for welding. Push it through the tube. At the bottom rear of the plane you will see it bulge. Cut a small hole in the covering with an Xacto knife. Then tape the antenna to the wire and pulled it through.
Good Luck!
Shubova
[8D]
Thanks, I should've thought of that. I'll give it a shot, the next time I disassemble the SS. Right now, I'm adding the flying wires.
