RCU Forums - View Single Post - 55AX running poorly at mid throttle
Old 07-28-2008 | 10:59 PM
ChuckW's Avatar
ChuckW
Default RE: 55AX running poorly at mid throttle
It should transition well and have smooth idle & mid-range. If it starts sagging bad or dies when you accelerate then you may have gone too far. Just lean it in very small increments, clear it out then see what the adjustment did. If you lean it too far, just back it out 1/8 or so until it comes back.
