RE: 55AX running poorly at mid throttle
When you are getting close to the right low end setting an 1/8th turn can be way to much. A 1/32 turn OR EVEN LESS may get better results. Take your time keep it a little rich for the first 1/2 gallon or so of fuel. to lean will cause A LOT OF WEAR. [8D]
