ORIGINAL: 67685
Jim,
Both receiver packs will be Lipo.
I have also thought about replacing the JR connectors on the batteries / reg`s, to a kind of "mini-deans" . Maybe they will manage for a longer time ... They could be easily replaced also ..
I saw an article somewhere here in this forum, using two Jaccio reg w/switch, and only using one switch; controlling both reg`s !?. hmm, i have a dosen of the Jaccio reg without switch ,every type... trying to find a good solution for them :-)
If you are using redundant power sources, it is not important to have the fail safe function of the Perfect Switch Harness as it is unlikely that both would fail at the same time. So in your case the regular regulators should be fine and probably more reliable than a single battery with a single regulator. But to answer your question, yes I can build a two regulator/one switch, switch harness. Contact me at:
[email protected]
Jim O
