ORIGINAL: farr30
it had problems with idle. We adjusted the needle valve and the carb.
Farr301
You adjusted the needle valve and does this mean you also adjusted the low range bleeder screw.
If so are you aware that bleeder type carbs work the opposite of most others (double needle types) And that you unscrew the bleed screw to lean the mixture. I agree with the above I think your midrange is rich.
John
