RE: OS .46 engine problem, Any Sugestions?
shawn,
a couple simple things to check first, are the fuel lines connected right ? clunck line going to the carb vent line to exhaust ? clunck stuck in the front of the tank ?
make sure all lines are tight with no leaks. is the fuel tank rapped in foam rubber so the fuel doesnt foam and get airbubbles in the lines ?
bassman
