RCU Forums - View Single Post - 55AX running poorly at mid throttle
Old 07-29-2008 | 04:18 PM
bruce88123
Default RE: 55AX running poorly at mid throttle
The fins are definitely for cooling and are meant to give additional surface area to transfer heat to the airflow.
Can you use the manual http://manuals.hobbico.com/osm/55ax-manual.pdf and the carb part list http://www3.towerhobbies.com/cgi-bin...I=OSMG2518&P=Z to explain what YOU call an injector?
