RCU Forums - View Single Post - engine head temp
Old 07-29-2008 | 05:48 PM
BillS
Default RE: engine head temp
ORIGINAL: hurk1
Does anyone know of a "rule of thumb" to be used for an engine head temp? How much difference is there between 2- stroke and 4- stroke?
From other experience oils in the combustion chamber start to break down above 450 F. The head and cylinder will be a much lower temperature than the combustion area. One of my friends shoots the temperature at the base of the cylinder and uses 220 F to 250 F as a guide while the engine is running. If the temperature goes up rapidly on throttle up or idle something is probably wrong.
Temperature measurement when used with caution could be a good tuning tool but most tend to reject the possibilities and very little data exists.
Bill
