RE: slanted hinge slot
What do you mean by "slanted?" Anyway, as long as the opening of the hinge slot is centered in the TE of the wing and the LE of the aileron I don't think it matters if the slot is "slanted." (I assume, by slanted you mean the slot angles upward or downward if viewed from a cross-section.)
Or, as long as the aileron aligns with the wing, you'll be fine (providing there is enough "meat" around the hinge to hold it securely).
