RE: engine thrust angle
175 cm = 1750 mm. You need to check your measurements from rudder to prop. I suggest that you use a larger prop. Even better use square aluminum bar that is around 50 cm. Make sure that the prop hole is in the center of the bar. Increasing the prop diameter will make the measurements more accurate.
Vicente "Vince" Bortone
