RE: engine thrust angle
Yes, you need to move the engine left. Usually I move the engine around 5 mm left to get it centered. Try the mix you will be surprised. You won't noticed other problems since this is small amount (1-3% mix). If you need more than this you will need to adjust the engine.
Vicente "Vince" Bortone
