RE: Redcats Monsoon Thread
OFNA makes them them. They are slotted from one end to the other. You also have to dremel out the hole for the flywheel to make it not hit the chassis because you are moving your motor so far forward. The mod is worth it to do. This way you can get a clutch bell alot easier if yours messes up.
