RCU Forums - View Single Post - Compression Question
Old 07-30-2008 | 12:56 PM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Compression Question
Unless you have ugly varnish on the rest of the engine to remove, there is no need to do anything. Just add a little oil down the glow plug to lube it before your first start up. The heat and fuel will loosen the ring up and the compression should return.
