RE: engine thrust angle
in other words is there any diffrence of P-Facor affect between normal and inverted flight ? if P-Factor force is linear to the prop rpm then i whould think using rudder to throttle mix will be much more affective then a constant right thrust angle that will be affective only at high rpm am i missing here something ?
