RCU Forums - View Single Post - engine thrust angle
Old 07-30-2008 | 02:26 PM
vbortone
Default RE: engine thrust angle
You got it right. The problem is that you can not do all with mixing. You have to use both and take the advantage of having both to compensate. I think you need to try and let us know how it works for you. It is easier to do the mixing than changing the engine so why not.
Good luck,
Vicente "Vince" Bortone
